Additional High Mounted Marker/Turn Signal Lights
The T@G comes just with the three high mounted marker lights. I wanted high mounted brake and turn signals rather than marker lights. I called Elsie at Pleasant Valley and got 4 of the new T@G clearance lights to match the 3 lights already mounted above the galley hatch. Under $5 each. The only other place I could find online wanted $14 each.
Installed the additional marker lights. Wires are run down through the plenum area behind the AC unit. Wired up with suitcase connectors. I wired the 2 outside lights as turn signals and the others as brake lights.
