Amplock Tls2, anybody
JohnnyLocoJohnnyLoco Member Posts: 195
edited August 2021 in Modifications & Upgrades
    Interesting, that's the first I've seen it. It looks solid, seems like it would work. But it doesn't secure the chains (that I saw looking quickly).
    edited August 2021
    What is the porpuse of locking the chains, when someone who want the trailer could easily rig the locked chains with and other chain, only using the same type of hooks?
    edited August 2021
    There is no reason to lock chains. I’m a twenty year soldier and a prior trailer thief.
    I was just trying to make sure it fits.
    You can steal a tag regardless of security measures but this might slow down the crackheads a real boot would probably be the best deterrent
    I agree with you on the slow down part. And I am no former trailer thief but If I wanted to steel a trailer, I know how easy it would be. 😊
    I merely mention it as a difference between that lock and others. The chains are a concern to some, thanks for the attack. :o
    I use one similar to that (it works well) plus other devices as too.
    edited August 2021
    Just don’t understand what someone is trying to prevent by locking chains.
    Mask don’t work either.
    edited August 2021
    That was a real question about including the chains in the locking system. I have to appologise, since I forgot the question marks at the end of my sentence. But it was a real question.
    Cause in my mind, no matter what you do, you still have plenty of places to hook up the front of a T@G or any light weight trailer and leave with it. Even the lock becomes a block to wrap a chain or cable around.
    Anyone ever tough about locking a 2 "in ball in the hitch" and if you worry about the chains, then simply modify them so that they would get a hook at both ends and remove them when stationary.
    Oh, and I do understand that mask do not works on a flat earth. But on a round globe..... 😉
    Just my 0.02$
