New Fridge
LightingguyLightingguy Member Posts: 2
I just installed a BougeRV 26 qt fridge in my '22 Tag Boondock. As I suck at carpentry, I opted to purchase a pre-made fridge slider. The model that Bouge sells is unfortunately too wide to fit into the fridge bin, at 22" wide (they do not show this on their website). I then sourced and ordered an IceCo slider, whose dimensions I could verify and which fit perfectly. I installed the slider on 1x3, with a center block to support where the bin floor is angled.
NuCamp tech support verified the floor material is 1" thick of Fiber and Polycarbonate and can be screwed into, which I did using wood screws. Then I installed the slider. The 1x3 is needed to raise the slider so as to not hit the U shaped latch piece mounted on the kitchen edge. For wiring I noticed the space behind the kitchen USB and cigarette lighter outlets, I pulled that, drilled up into that space from the ceiling of the fridge bin, cut off the cigarette lighter male connector as supplied by Bouge, then hard wired to the feed supplying the kitchen cigarette outlet
As the wiring back to the fuse panel is #14, this should be adequate for the load, which as far as I can tell is about 4 amps on the fridge when running at max. The 26qt is an inch shorter/lower (14.5" high) than a 30 qt (15.5" high), the model I had wanted, but I had a feeling the larger 30 qt might not fit. It's a close thing as when you add height, on top of slider that is raised to clear the hatch latch, you lose depth of the fridge due to the curved shape of the kitchen hatch. My 26qt seems to be just right.
And I have no clue why the images re 90 deg., and no idea how to fix, sorry.
    edited April 2023
    @Lightingguy - take phone photos in “landscape” mode and they will automatically reduce in size and not flip when posted.
    I edited and reposted your photos.
    Nice job on the slide. We had our TaB built back in 2017 with a slide sourced from Southern California Teardrops.
  • LightingguyLightingguy Member Posts: 2
    Thx for fixing the photo's and the tip
    Irfanview is a great basic photo editing software for PCs. Free download for PCs.
  • HuggingtheshoreHuggingtheshore Member Posts: 7
    @Lightingguy, can you verify that this is the CRPRO25 model (https://www.bougerv.com/products/crpro25-12v-camping-fridge). Also, did you consider getting the add-in power pack that Bouge sells (https://www.bougerv.com/products/crpro25-26-quart-portable-car-fridge-with-220wh-power-station)? Just curious. And thanks for posting this!
    I've got that Iceco JP-series slider; the one in the photos sure looks like the same one.
  • akgrownakgrown Member Posts: 3
    This slide looks great. How many inches between the top of the refrigerator and the countertop? If this works with my frig, I'll install as you have. I also have a '22 T@G. Thanks!
  • JohnxlJohnxl Member Posts: 4
    When you mounted the refrig to the slider,...did you bolt the frig to the slider or just stap it in place?  Thanks for a responce
  • SpeckmanSpeckman Member Posts: 19
    Thanks to the person that told me about the Igloo ICF32 cooler.  It fit our 2016 Tag drawer without needing construction.  Walmart $315.00!
    We will be traveling to NuCamp in March and will post about how it works.  We bought a 2nd one to use in the car, too.  I hope it is energy efficient on batteries.
    edited March 2025
    I own a 2018 standard 5-wide T@G with a Norcold NRF-30 powered with a 100Ah lithium battery. My Norcold still works great.
    I recently purchased a BougeRV portable refrigerator (30 Quart [28L] - CR28). Purchased direct from BougRV for $202.50. It arrived very quickly and in good shape.
    I purchased with the assumptions that it could be a drop in fit in my T@G when the need arises.
    Size is 22 3/8 Wide x 12.5 Deep x 15 3/8 High.
    Since my NorCold NRF-30 is still working fine, I did not attempt to place the BougeRV on my slider.
    I believe I would need to make a 1/2-inch modification for the new unit to fit properly.
    I did some extensive testing (3 days) with the CR28 and found that the stated specifications were accurate. I tested with a Renogy Battery Monitor, Poniie Electricity Monitor (PN2000) and Sovarcate Infrared Thermometer. I started the test using the AC adapter and after around 1-hour, switched over to 12-volt for the remainder of the testing. In non-Eco mode using 120-volt AC, the power draw was around 48-watts while running.
    After four days I ended my testing. My LiTime 100Ah lithium battery went from 100% down to 54%. In Eco mode the BougeRV CR28 pulled around 36-watts when running and around 1-watt in standby. I would say it ran less than 33% of the time during testing (15-20 minutes sporadically each hour).
    Temperature thermal readings were as expected (fluctuating +/- six degrees. Exterior reading of BougeRV outside walls averaged around 70 degrees. No hot spots were noted. The CR28 was set to 35 degrees for the test.
    While not in desert heat, my testing indicated I could expect up to 4-5 days of use without any solar recharge. Maybe 15-20% more efficient than the Norcold NRF-30.
    I anticipate taking both coolers and my self-built 100Ah power station with me on my next trip.
    While not a two-zone refrigerator/freezer, I think one could reach a happy medium with frozen at the bottom and non-frozen at the top.
    I would recommend the BourgeRV CR28 it is a good option to replace a Norcold NRF-30.
  • 2022TAGowner2022TAGowner Member Posts: 21
    This is super helpful. I also have a ‘22 Tag. What battery are you using to support this fridge? I’m in the process of getting a fridge and battery.
    My installed battery is a 100Ah Renogy lithium battery ($800) since then I have purchased two LiTime Smart 100Ah lithium trolling batteries. I highly recommend them. My last one cost me only $203.
    My suggestion is don't spend a lot.
    Do your homework on electrical wiring.
    I would run 14-12 AWG and make sure your connections are good. 10AWG is overkill, but it only hurts your pocketbook.
    Good luck.
  • arubinoarubino Member Posts: 16
    @JamesDow - did you make the retrofit on the Bouge yet?  I have the exact same one - you almost have to carve out 1/2" from the bottom of it to get it to fit...and because the slider rails are on the inside of the slider itself, i can't 'carve' out a notch to fit the cooler...what do you think?
    @arubino
    My Norcold NRF-30 is still functioning fine, so no I have not made a retrofit for the BougeRV refrigerator (CR30) I have.
    I know that the BougeRV unit is not an exact size match.
    What I thought was maybe a workaround to gain the extra room would be the elimination of the 1/4-inch sides to the existing slide tray. (gain about a 1/2-inch total)
    How the complete mounting on the tray without too much problem is still up for thought.
    My thinking of what could be possible would be:
       Mark (exactly on wood base) the attachment points between the sliders and the wood base tray
       Remove the tray from the sliders
       Remove the sides off the wood tray
       Reinforce the existing front and rear on the wood tray
       Attach a steel L bracket to the wood tray (use the markings previously performed)
       Mount the wood tray and brackets to the sliders using machine screws and lock nuts (nylon)
    It is the inverted steel L brackets that replace the removed wooden sides and may provide the needed additional width for the refrigerator.
    The head of the machine screw would need to be low profile and curved. Low profile nut would be positioned on the slider. Positioning the steel brackets would need to be near exact matching holes on sliders. (Maybe the hard part)
    I would put rubber contact grip non-stick shelf liner on the tray to minimize any slip.
       See attached drawing.
    With a bit of luck, this setup may work. I will not know until the need arises.
    Good luck in making yours fit.
    »» Let us all know how things work out. I hope it may be something easier than my preliminary workaround.
    ________________
  • DCN082162DCN082162 Member Posts: 34
    I Just finished installing the Bouge 28 in my T@G. Here's how you do it.
    Mount the sliding rails horizontally instead of vertically as they are from factory. This gives you the height you need and a bit more. However the factory slide rack is about 3/4" too narrow for the Bouge, and the side rail, if left in its factory orientation will interfere with the power connection. So what you do is swap the orientation of the side rails to put the long side horizontally and the short side vertically. Then you will have drill some new holes in the bottom and side rails to allow all this to happen as the rails mount through the side/bottom plate. This arrangement definitely works. It took some time to figure out and a few errors to figure it out. When I do the final fit up and tightening I will try to take some pictures or video.
    please do, I am interested.
