Does anyone know of a clip that can be put in the keder rail such that I could tie a guy line to it? I typically like to put up a tarp on one side with telescoping poles The challenge is getting it secured to the camper. I use guy lines tied to the grommets on the tarp and have to pull them across the top of the camper and down to the bottom of the other side: the back lines attach to the stabilizer assembly and the front attach to the handles or the front deck. Thank you!
I do not have Keder rails installed on my 2018 5-foot wide standard T@G.
I clean some spots and use four suction cups with a tarp and then other end of tarp held up by poles.
My poles are just PVC with 2-foot rebar driven in the ground to hold them. No guy-wires or lines needed.
Even in some strong winds, the suction cups and poles have not failed.
Thank you for the reply. I have bought many suction cups and cannot get them to hold — much less in wind.
I successfully use suction cups too. I think cleaning the location with windex and a rag or a window wipe before placement is the key.. Edited. I use exactly the same suction cups as GulfCoast below, I have traveled thousands of miles with them clamped to the roof of our T@G.
We bought a set of these heavy duty suction cups to anchor an awning. They stay attached for months.
https://www.amazon.com/gp/product/B08N13T8X2
I like @JamesDow's rebar and PVC pipe idea. Simplicity is a good thing.
I have those same suction cups. I'm going to try and clean them with alcohol and then clean the roof locations, as I have not had success getting these to stay on.
Yes, I do like the rebar idea. That assumes, though, you can get the rebar into the ground.
We use these for our Sun shelter:
iRomic Heavy Duty Vacuum Suction Cups Hooks (4Pack) Specialized for Kitchen&Bathroom&Restroom Organization
Touch the image to zoom in
Brand: iRomic
4.4 4.4 out of 5 stars 1,245 ratings
Amazon's
Choice
in Home Storage Kitchen Towel Hooks by iRomic
-24% $15.99$15.99 ($4.00$4.00 / Count)
List Price: $20.99$20.99
Same-Day
FREE Returns
I would caution using suction cups. I have an outdoor changing room mounted on the rack that came with my Tag XL. On a recent trip to Idaho, I was using suction cups to secure parts of the room to my Tag. The suction cups on the sides were fine. I did use one on the roof as well. I noticed the one I used on the roof now has permanently left a circle in the paint where the suction cups was. I speculate that the suction cup on the top was exposed to more heat due to direct sunlight and was the cause of the damage to the paint. YMMV.
@rcarey, my suction cups are clear and have been exposed to very high desert sun and my T@G has not experienced any marks or discoloring.
Were your suction cups clear?
I experenced discoloring on my car by placing a black water/shower bag on it. After about 8 months it finally faded away.
Thanks for the word of caution.
