I just paired my iPhone with a Victron controller. Use the 3 vertical dots, “Reset Pin Code”; then enter the PUK code found on the back of the controller. Once it accepts the PUK, I think it resets the pin code to 000000, but you will be given an option to change your pin. Hope this helps.
Thanks the controller is screwed to side wall so-was looking for pin #, but default is six zeros, so , taking a break, it showed up once on my btooth list, so something is trying 🤪
Controller or battery monitor?
Took off controller, puk # was on back, entered, presto, all good, battery shows. Good 12.9 charge, turned battery disconnect off, ready to play😀
