Water pressure regulator
MOHOMEMOHOME Member Posts: 2
Does anyone add a water pressure regulator to the shore connection just to be safe? We have not taken ours out yet, so a real newby.
  • JamesDowJamesDow Member Posts: 714
    I use mine when rarely attached to water. It is always attached to one of tree 10' hose sections. I usually just fill up my tank and use that instead of shore water.
    I always use one on my city water connection; a habit I got into years ago when I hauled a pop-up around. It's cheap insurance.
    We never connect to a water system, and just fill the tank with a plastic jerry can. It avoids hauling a hose and pressure regulator and removes a trip hazard. And a leak hazard. If we had unlimited water in the sink, we'd have to do something more complicated than a plastic dish pan to catch the drain water for dumping.
    For those who do connect to pressure water systems, I have an unused Camco marine/rv water filter that I'll pass on to anyone passing through Ocean Springs, Mississippi. It came with the camper and we'll never use it.
