Victron IPhone hook up
Keep trying the 000000 code, still won’t hook up, is there a code on the Victron somewhere? Thanks
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 680
    Controller or battery monitor?
    I just paired my iPhone with a Victron controller. Use the 3 vertical dots, “Reset Pin Code”; then enter the PUK code found on the back of the controller. Once it accepts the PUK, I think it resets the pin code to 000000, but you will be given an option to change your pin. Hope this helps.
  • PrismtagPrismtag Member Posts: 27
    Thanks the controller is screwed to side wall so-was looking for pin #, but default is six zeros, so , taking a break, it showed up once on my btooth list, so something is trying 🤪
    Took off controller, puk # was on back, entered, presto, all good, battery shows. Good 12.9 charge, turned battery disconnect off, ready to play😀
  • JoeFridayJoeFriday Member Posts: 9
    Anyone get a message on your phone saying something to the effect of  "unable to connect to Low energy device"??     I looked at my charge controller, but did not look at the back since I'd have to unscrew it from the panel.  I'll give that a try.   I DID see that it was emitting a blue light, so I feel like it IS working. Am I correct in that assumption, at least??
    SUCCESS!!   I was surprised to see a reply from VICTRON in my email a few minutes ago.  They were able to supply me with my PUK #, and now my Android phone is paired with the control charger and I am reading all the performance data.  Everything appears to be in good working order.   I changed my PIN to 123456,  and documented the PUK and new PIN for my records.  What a relief!
