I can’t get our water pump to work. I cleaned the filter, primed the pump by putting water in the intake hose and submerging in water, and even replaced the pump with one my dad had that he knows works. It won’t pump water. I can hear it run so the fuse isn’t blown. I don’t know what else could be the issue. Any ideas?
It’s a 2022 Tag we bought used just a month ago. It was fully winterized with antifreeze in all the lines.
What happens if you loosen the connector on the discharge side of the pump and run it? Does any water at all escape?
Is it possible that the polarity of the 12 VDC wiring to the pump is reversed?
Manual: https://www.pentair.com/content/dam/extranet/web/nam/shurflo/manuals/911-1008-4008-rv-by-pass-pump-iom.pdf
