Fender Lights
On our last trip, I noticed the fender light on the passenger side was flickering on and off. Upon inspection, I noticed some kinks in the wire where the tire had rubbed on it. I cut and spliced the wires and moved it out of the way of the tires and it works fine. My bigger concern is why the tire would rub on the wall of the trailer. It obviously isn’t doing it constantly or I would’ve had a lot more problems. it probably happened when I hit a big bump. Just curious if anyone else has had similar problems. Not sure if I have a problem with my axle or not.
2021 Tag XL Boondock
Chevy Colorado ZR2
Subaru Outback
