Has anyone replaced the rubber seals and hinge cover? Doesn't seem overly complicated but I am always looking for a video or someone with some wisdom. Mine is 2017 and I've developed a small leak. This may not be the source of the leak but I might as well due to age. I have ruled out handle/lock openings and narrowed down to right side lower corner as facing from the rear.
The hinge cover is part id 78-85-7008
The rubber seal is a type of Q seal and I sent request to Nucamp support to make sure I am getting the right part.
0 ·
Shout out to Barb at Missouri Teardrop Trailers. Prompt professional service, while the local guys, crickets. I am sure this could have been done with off the shelf products, but I chose a source with less if's, I hope. Parts #'s below.
Anyone else tackled this project? 7 plus year old seals and galley hinge cover, so I chose to completely remove existing and replace all.....Before I thought about the process. I have some experience with this on a previous td and all went well, but there wasn't a galley light wire to contend with. There is about 10" of play in the wire but I know not disconnecting is inviting trouble. Seems like I could remove the light and pull the wire out, then pull it back through when complete but that is in theory, mine. A little help please.
Dan
Seal on opening - 18'
Part number 78-85-7014 and price $2.00 per foot X 18' = $36.00
Seal on door - 18'
Part number 78-85-7016 and price $3.00 per foot X 18' = $54.00
Hinge cover - 1 each
part number 78-85-7008 and price $25.99
Shipping estimate $21.88
Total - $137.87
What is it so I can replace is my next question?
I think the semi-rigid black matter you're talking about may be old butyl caulk. I found similar stuff when I took the large exterior handles off my 2019 Tag to reseal things.
