I couldn't find this topic on the site, although it's surely been covered many times, but how often do you folks get your wheel bearings repacked? And is there any truth to the worry that axle grease will settle away from the bearings if the trailer sits unused for months at a time?
Thanks for your thoughts!
0 ·
Lower front trailer tongue all the way down. Lower one side stablizer. Crank up tongue and wheel will lift so it can be spun and greased. Repeat for other side. Very easy process.
I have no idea what grease to use (lithium?/marine grade?)... suggestions @JamesDow?
TV: Volvo XC-60 T8 R
I do a lot of hot weather camping, so high temp grease was a consideration.
Below (photos) is what I use.
PROCESS:
It is important to spin the tires when adding grease. Thin latex gloves are good to have and some newspaper to protect floor/ground. What you are doing is pushing out the old grease. (When grease is pumped into the fitting, it is channeled to the bearing and eventually back out the grease cap hole). Be cautious of some sharp edges inside when cleaning up. Everything you will be doing is outside of where the bearings are. Pump out any air out of the grease gun.
Pop plastic (T@G) cap off with flat head screwdriver. Next, using screwdriver, pry off the black rubber grease cap (about 1 1/4" dia.). Now you should have access to grease fitting. Up to this point all is external to bearings, so should be clean. Push your grease gun onto grease fitting (click). Start slowly turning the wheel and pump the new grease in. (New grease should not be escaping immediately if grease gun is attached to fitting properly). After a short while the old grease will start pushing out. It may be different color than what is being pumped in. You can use some paper towels to wipe it away as you proceed. Pump some more in to replace old and you are done. Remove your grease gun. (May take a little effort) Use paper towels to clean up any grease mess, replace rubber cap. Clean up 100% of any grease (watch sharp edges) replace plastic T@G cap and crank back down the tongue all the way and crank up stabilizer. One side done, repeat on other side. Entire process less than an hour.
I will no longer fear the unknown of what is behind that little hub cap (and look forward to putting another 10k miles on our rig so that I have a reason to pry that sucker off.)
Before putting on the exterior plastic silver T@G cap, the inside area should be clean with no grease showing at all.
