Updating Your Power Center for LiFePo4: WFCO or Progressive Dynamics?
2»
  • Jms
    Jms Member Posts: 73
    I also found this video featuring a WFCO technician (https://www.youtube.com/watch?v=f7MA5lKMf9A). I'm going to try their recommendations for charging and mode switching and report back.
  • Jms
    Well, needless to say the recommendations in the previous video did not trigger the lithium mode. In the video, the WFCO technician seems to indicate that they didn't want a manual switch because folks might make a mistake on which mode to use. They also make a lot of excuses for why the autodetect might not work and mostly blame the RV manufacturers - cable runs too long, wire gauge too small, etc. Their solutions aren't really workable - re-wire with heavier gauge wiring, add a second power center closer to the battery, etc. So mostly the video seems to be them trying to counter all of the negative comments on forums about how their autodetect does not work.
    So I ran my battery down again and plugged into shore power with the breaker for the converter off. I then flipped the breaker and lo and behold the converter was delivering 14.2 volts at 20 amps. However, this only lasted for a few minutes before both the voltage and current fell to 13.5 volts and 4 amps. The battery gradually charged over 10 hours at that rate and topped off at 98%. The red bulk charge light never came on, and the converter stayed in lead acid mode (green light). 98% is pretty good, and I'm happy with that level of charge. Essentially the converter when plugged into shore power is in 'power mode' and trickle charging the battery due to the voltage difference - as this difference decreases the current is also decreasing until the battery and converter power are in equilibrium. This will work for me - there just isn't any 'fast charge' mode with this condition.
    I've left multiple messages with WFCO tech support asking for a jumper to force the converter into lithium mode. I've gotten no response. I've tried their warranty and order lines too with no answer from anyone. Not sure what is going on, but WFCO customer service appears to be nonexistent.
    So, in the end I could have kept the original 8725 and just charged the lithium battery in 'power mode' as the 8725-AD is doing now and saved several days worth of work and some cash. But it did give me the opportunity to discover some of the sub-standard wiring that NuCamp had done and correct that. We'll see if WFCO ever contacts me. I'll probably keep sending them weekly messages and update if I hear back.
    For those trying to decide if they should replace their original WFCO 8725 with an AD model or trying to decide if they should instead go with a Progressive Dynamics model, I hope my experience helps with your decision.
    JamesDow Member Posts: 751
      I am surprised that WFCO has not been responsive. I always got to speak with a knowledgeable technician every time I needed.
    As far as changinging my converter in my 2018 T@G when I switched over five years ago to lithium, I did not. I do not find the need.
    My onboard converter will charge up my lithium battery to 84% when plugged into shore power, but if plugged in with my refrigerator running, the charge will reach 96%+.
    The difference is how the converter cycles between various converter operations modes (absorption [13.6V]/bulk [14.4V]).
    Besides changing out my USB outlets, I have had no wiring issues or concerns with my T@G.
    As far as getting my lithium to 100% SOC, that takes place under solar or when I use a battery charger which I easily connect up via my SAE plug. Lithium batteries need, a 100% charge to start balancing the cells.
  • Jms
    @JamesDow thanks for the comments. Yeah, not sure what's going on with WFCO, but I hope they get back to me at some point.
    In the end, I think your strategy is probably for the best. The existing 8725 can charge the lithium battery to well over 90% (mine is like 98% from the lead acid mode on the AD version). Solar can do the rest, or an occasional top off with an external charger to balance the cells. My PWM solar charger (Renology Voyager) will just get the battery to about 98% also - a MPPT would likely get it to 100%. But I'm probably not going to change mine out - just occasionally top off with an external charger.
    So essentially my current set up is for the lithium to be slow charged by the WFCO when plugged into shore power to about 98%, the lithium to be also slow charged while connected to solar (about 4 amps at 13 v from my 100 watt solar suitcase) to about 98%, and for the lithium to also be slow charged by the tow vehicle while driving. I'll occasionally top off with my Noco Genius external battery charger to balance the cells.
    In the second video I linked above with the WFCO technician, they discuss that LiFePO4 batteries shouldn't regularly be charged to 100% in order to extend their lifetime. So I feel my routine 98% charges may be better for the battery anyway.
    Thanks again, and happy camping!
  • Jms
    edited June 3
    I finally got a call back from WFCO this morning - Austin Milcherska was very nice and agreed to send me a jumper for my AD unit to force it into lithium mode exclusively. He also sent installation instructions in a follow up email. I'm attaching them to this post for reference.
    We also spent a little time trying to troubleshoot the issue. Basically he said that:
    • The battery has to draw over 22 amps in order for the converter to ramp the voltage up to bulk charge. Mine at most has pulled 19-20 amps while in a low charge state.
    • The battery should be drained to 10-20% in order to facilitate the 'detection step'. Mine was down to 20%, but even at that charge level the voltage was still 13.1 volts, and the 'detection step' did not work.
    • At the end of the charge cycle the converter will switch from a green to blue light indicating the lithium charge profile. Mine did not do this. It stayed green both times I charged from a depleted battery.
    • Many batteries do not require a higher voltage charge mode. I'm not sure what this means. All batteries should be able to trickle charge.
    • Voltage drop is a serious issue. You should have .3 volts or less of drop. I imagine this is referring to the distance between the converter and battery along with the wire gauge issue. Something I cannot control.
    • The battery controls everything to do with the charging - the converter just provides the voltage; the battery takes care of everything else. The battery BMS likely isn't limiting the incoming current, so I'm not sure how this applies. The converter should provide the appropriate voltage and if it's not seeing the battery as depleted then it is not providing the voltage.
    It looks like from the instructions that the unit might need to be pulled to install the jumper. I may wait a short while before trying to install it since I'm a bit tired of removing and reinstalling the converter. I'll report back once I do install it. Until then I'll just trickle charge the battery.
  • The_Rigger
    The_Rigger Member Posts: 204
    “In the video, the WFCO technician seems to indicate that they didn't want a manual switch because folks might make a mistake on which mode to use.”
     Speaking as a manual-switch model owner, I’m glad I didn’t see that video before I bought my WFCO. If I did, I’d’ve told WFCO to take their power center and… Well…. You know.
    I’m not even sure how you could make a mistake like that; if you’ve got a lead-acid battery you use lead-acid mode. If you’ve got lithium, you use lithium mode. Seems pretty straightforward and mistake-resistant to me.
  • ras
    ras Member Posts: 213
    Have you considered just making a jumper from a short piece of wire?
  • Jms
    So since my last update, I did receive the jumper from WFCO. As @ras indicated, once could be made with a short piece of insulated wire - you would just need to match the plug or potentially solder the wire on the first two jumper pins.
    Per the instructions, I had to pull the unit from the wall, remove 4 screws holding the fuse PCB and bracket in place to access the board with the jumpers behind it.
    It was a little tight getting the jumper on.
    Success!
    After it was reassembled and power restored, the blue light!!!!!! Yeah!
    So the jumper procedure appears to have worked and forced the unit into lithium mode as indicated by the blue light. I drained my battery to about 90% and plugged shore power in to see how it would perform.
    Initially, I'm disappointed. In lithium mode, the WFCO charged the battery identically to how it charged it in lead acid mode. The WFCO pushed about 4 amps at 13.5 volts and never reached the 14.5 volts to top off the battery, leaving it at less than 100%. I'll have to drain the battery more and see if it performs differently. I'll also need to replace the 20 amp fuse with a 25 amp one since at lower battery levels the WFCO may push more than 20 amps. The 10 awg wiring should handle up to 30 amps, so the fuse swap should not be an issue. Not sure why NuCamp originally installed a 20 amp fuse since the unit is rated at 25 amps - possibly the lead acid battery never pulled enough amps while charging to matter.
    Anyway, if the WFCO in lithium mode never is able to top off the battery, then I would say it's not worth switch out a non-lithium 8725 for an autodetect version when swapping your lead acid battery for a lithium one. I'll periodically use my 10 amp NOCO charger to top off the battery as it is able to push all of the cells to 3.4 volts and balance them with a full charge.
    I'll report back if a lower battery level is able to trip the WFCO into fully charging it. Until then, happy camping!
  • The_Rigger
    There have been lots of reports of the auto-detecting 8725s not reaching proper charge level for lithium-iron batteries, most notably over in the T@B forums. That’s why I went to the time and trouble of hunting down a new-old-stock manual-switching 8725. I’m not terribly impressed with WFCO in general.
  • aBiNeR
    aBiNeR Member Posts: 17
    edited September 6
    This is a fantastic thread.  Thanks for all the info!
    One question if I may:  My 23' TAG has 8725 AD running firmware version 1.19.  Does anyone know what firmware version is required to even consider beginning the adventure of upgrading from AGM to a lithium battery?
    Thanks in advance.
    I have a 2018 standard 5 wide. When I switched to a lithium battery, I purchased a battery charger ( < $70 ) and the process and system has worked great.
    Advantage of a charger vs a converter is an assured 100% charget to balance cells. It also provides other options, like charging my power station and other batteries.
    While a new lithium converter is a good thing, I have never seen the need or desire to change my converter. If I can get 84% ○ - 96%+ with my WFCO, why bother with a change.
    Easy, plug charger directly in my solar SAE plug and charge up.
    That is just my opinion.
    ____________
  • The_Rigger
    It’s my understanding that all 8725AD power centers are supposed to be able to handle a lithium-iron battery properly regardless of firmware version. However, as noted elsewhere, the auto-detect circuitry wasn’t exactly ready for Prime Time when WFCO first brought it to market; that’s why I went to the trouble of hunting down a manual-switching version.
    I’d guess that you couldn’t really go wrong by updating to the most current firmware version, and if that version doesn’t do the LiFePo4 trick properly, then dump the WFCO entirely and get a different brand of power center. TBH, knowing what I know now, I’d probably have gone with a Progressive Dynamics unit instead of another WFCO…. But that’s just me being me, and your mileage may vary.
  • aBiNeR
    Appreciate the response.  Thank you.
    I actually got a hold of Austin at WFCO today.  He confirmed that V1.19 is required for lithium battery charging, though they are up to V1.21 at this point (fixes for Battle Born battery compatibility only).
    I'm going to give it a go with a lithium battery drop-in (replacing 2 AGMs), and I'll wire in a separate AC lithium charger as a potential backup to not being able to charge from shore power beyond 80%.  If I wind up needing a jumper, then so be it.  The only other concern I have is if charging lithium from the 7-pin when towing will put a strain on my tow vehicle's alternator (one of a few potential drop-in concerns in general).
    I have been towing my 2018 T@G for around 15,000 miles with a Renogy lithium battery using a 2012 Toyota RAV4 (4 cly). I insalled a cut off switch between my tow vehicle and trailer. This allowed me control as to when I want to use the TV alternator to charge and it also can eliminate any draw from the T@G battery back into the TV battery.
    I typically turn off any tow vehiclej charging in congested or rush hour traffic. The value of the amount of charge received (11% per 200 miles highway) is OK, but often not a major consideration.
    Does it put a strain on  your alternator, I would say yes. Especially if your vehicle (like mine) is not equiped with a extra strong alternator for towing.
    I would suggest having a adapter plugged in so you can monitor output via you 12-volt output (cigarette lighter).  My output is around 14.1 - 14.3 volts.
    Bottom line, pull the fuse out at the battery if you have concerns. All other functions (lights) should still work fine.
    My go to plan is start the trip with a full lithium battery (that gives me 3+ days of refrigeration). I use solar as needed. Any additional charge is a bonus.
