HikinMike
Member Posts: 400
I needed a wind deflector for the AC so I adapted a cheap one I found on Amazon. I just wedged it into the crack above the AC. Also, wanted somewhere to keep our phones that would be easily accessible while lying down. Found these two JAVOedge nets on Amazon which I mounted underneath the overhead bins. I also stuck a couple of puck lights inside the headboard compartment. Really helps find those things buried at the bottom.
Nice - I especially like the nets. Looks like they could come in handy in many places. One thing I did with mine is added a small shelf to the right of the AC. I used removable 3M hooks. I can easily remove the shelf of stuff a couple of cut pool noodles when I travel dirt roads. I use it for a Blue Ray Player, which I really only use for the video USB input it has. I hook up a hard drive with my movies (300+) and it also doubles for access to YouTube and other streaming services.
Nice shelf. Looks like an easy install too.
These are the nets I used
Cup/Drink Holders
Due to the curve of the wall, these things are useless to me. Especially if you have your drink in a koozie. Has anyone modified or done away with these?
