Road Shower
I came across this in an overland off-roading article. It is a pressurized solar heated water tank that seems like it would be a nice accessory boondocking. Kind of pricey but possibly the seed for some DIY versions.
https://roadshower.com/woo/?doing_wp_cron=1575251119.1262710094451904296875
    Nemo Helios just as good for $100
    Priced out pvc, tubing, valves, etc for a diy roadshower...easy to do...question is, "would you use it enough to justify the expense and time to build and trouble to carry around." Read reviews on the Helios...wouldn't trust it to hold together.
    I had looked at the Road Shower. Looks very nice. I've decided it would work better for me to buy a generator and use the hand held shower on the trailer. I would just fill the tank with some solar heated water or boil some on the cooktop.
    If a pressure shower is not a necessity, Front Runner Offroad has some nifty options. ANd as you have noted there are several DIY options on You Tube.
    I have looked at similar devices in the past... But for me it was easier to heat water up on a propane stove, mix it into a 5 gallon pail, use a portable battery operated pump with the USB plug for charging and use the pail later for storage. I also had a small teak wood platform that stored my shampoo and soap and used a Trekker privvy tent as my shower enclosure. The tent was also used as a privvy area with my porta-potti so was able to utilize it well when boondocking.
