Unidentified object
Discovered these lying under the sink. Wonder what the hay. Look like they could be from a small pump. But pump seems to be all there and operational.
    Screws for the clamps holding the sink in. Look "up"....
    William A Thanks I'll check it out Tom
  • TomDTomD Member Posts: 358
    Those are doohickey’s that attach to the thingamajig so that the sink recognizes water.
    Kinda what I was thinkin. Being a XXL old goat, I ain't much into turning into a pretzel anymore to look up. Took my trusty shop mirrors and a flashlight. Did the best I could and see, nothing out of place or obviously missing. I have done a bit of crawling under and around. Greasing this and that, painting axle etc.
    Water works, sink did not complain. Do seem to have a broken off vent line from water tank to the outside doohihicky. Line is so dang short you can't play with it much.
    Played around with the funky wheel up front. Drilled and installed a lock pin.
    Damn I have a lot of hardware on the shelves after restoring the old Avion and the 66 pickup. Kinda handy. Even if you did have to by a whole box or dozen when you only needed one or two.
    Put her away for a while, trying out the new cover that came with her.
    I think I dropped them last year, thanks for finding them. ;)
    I think I am pretty certain the item on the right is a pen. Commonly used to write checks to finance mods on your T@G. =)
    Yup
