T@G Toolbox Tools
JamesDowJamesDow Member Posts: 676
Everyone carries some tools
I noted an early 2018 thread regarding Pre-Trip Maintenance and Tools thanks to WilliamA.
I thought I would start a new discussion based around tools that I found useful and why.
Due to weight, size and other limitations, I bring along the minimum standard items like pliers, wrenches, vice grips, screw drivers, socket set, tape measure, etc. I already carry some tools in my tow vehicle.
  • In addition to the standard items, I have a small cheap assembly of additional tools just for traveling with the trailer.
    Below are some of those travel items.
Please feel free to add on your items to the thread.
Thanks
OEMTOOLS 6919M 3/8 Inch Drive 19mm Impact Deep Metric Socket $2.28
---Uses: Stabilizer jacks, wheel lug nuts, crank down for spare tire
7 MM Deep Socket (1/4 Inch Drive) $3.48
---Uses: Black hand-knob to manually open or close the lid of the Fan-Tastic Vent Fan (if knob breaks)
HDX Screw Driver 16 Bit Set (Including Robertson Square Bits) $11.00
---Uses: Wall plates, Jensen radio faceplate
Powdered Graphite Lubricant $5.25
---Uses: Unstick trailer locks
10” Flat Smooth Cut File $8.00
---Uses: File back tongue jack (after making contact without wheel attached to asphalt or concrete)
Husky 40 Piece Stubby Set $10.00
Magnetic Flashlight $2.00
Stubby Hammer $2.99
Plastic Tool Case (14”) $6.00
Coleman Folding Shovel $7.00
. Silicon Lubricant $5.00
. Digital Multimeter Voltage Tester $13.00
. Camco T Level- Assists You in Leveling Your RV $2.02
. Foam Kneeling Pad (17” x 11”) $11.00
Other useful non-travel items
. AcPulse Pistol Grip Style Grease Gun $25.89
. Poniie PN2000 Plug-in Kilowatt Electricity Usage Tester Meter 26.99
