Generator question. Just purchased 2021 T@G XL Boondock
Having just purchased our first T@G trailer and wanting to make sure we had everything needed for boondocking. Does anyone know the size or type of generator that would be able to power our trailers microwave (not used a lot), air conditioner, and other electrical devices. Our trailer comes with solar panels to help keep the batteries (we have 2 6V batteries) charged. Any advice or help would be appreciated.
2021 Subaru Outback
MIddleton, WI / Santa Fe, NM
Just a helpful tip here... There is a lot of information within the forum area. If you tap on the search icon above and enter generator you will find a ton of information there regarding generators, member feedback and a good amount of discussion regarding AC units, etc.
Welcome aboard too and hope you enjoy your new trailer!
Congratulations!
2021 TAG XL Boondock
Toyota Tacoma
Evergreen State -
We have had great success with our Yamaha ef2000. I just wouldn't have the microwave and A/C on at the same time. You may need greater capacity if you wanted to use an electric coffee maker.
https://www.yamahamotorsports.com/generator/models/ef2000isv2
Toyota Tacoma
Evergreen State -
Dave, have you converted your Yamaha to use propane?
We have a champion 2000 watt from tractor supply. It runs the AC fine we do not have a microwave but I am sure it would power that. The only downside is that the generator is a bit load. The Hondas are less noisy. Most gas powered units around 2000 watts should be sufficient. Some of the bigger solar generators would probably work too but I think they are more expensive.
I would suggest doing a search on this forum under "generator"
Below are a few links that you will find:https://teardrop-trailers.vanillacommunity.com/discussion/comment/7074#Comment_7074
https://teardrop-trailers.vanillacommunity.com/discussion/comment/4868#Comment_4868
Thanks for all the responses. Very helpful.
2021 Subaru Outback
