Putting a TV in a 2021 T@G
We decided to install a TV in our new T@G. Here’s what you need to know.
  1. In the upper bin/ cupboard is a TV ready sticker. Behind that are RCA cables (audio) and a cable TV connection.
  2. if you remove the rear panel in the cupboard, you’ll find wiring. The black and white wires are your 12v power supply. Black is + (hot) and white is ground.
  3. If you mount the TV to the cupboard door (which I did), I was advised by nuCamp to move the hinges from the top to the side and use a VESA mount.
  4. The attached picture shows you the final result.
2021 T@G named Amelia Pond
2020 Mazda CX-5
Englewood, OH
