Installing a battery shut-off
I’m a NOOB with a 2016 Tag Max that doesn’t have a battery shut-off. I’d really like to install something comparable to what is installed on newer models, especially to reduce wear on my TV. Any advice is greatly appreciated.
    Pictured is a battery switch I was considering. You can find them on Amazon.
    Also pictured is a switch to totally cut power the Jensen Television. Gets rid of the phantom draw of power and shuts down the blue light which is illuminated when the television is off.
