Crank handle hits back on Jeep on T@G Boondock on severe angles.
So I was testing the Boondock offroad, and the handle hits the tire when I go through a big dip. Does anybody know if there are removable handles or some other solution for adding clearance between the handle and the back of the towing vehicle? I am thinking that if I could remove the handle or put in an electric jack, but I have zero experience with either.
Check out these threads:
https://teardrop-trailers.vanillacommunity.com/discussion/946/installed-jack-e-up
https://teardrop-trailers.vanillacommunity.com/discussion/699/new-trailer-jack
When I had my JKU I used a hitch extender with great success. On my G, I have a similar issue with the spare and am again using an extension.
In the future I may work the problem from the other side and either replace the jack with a removable unit or extend the tongue.
2019 T@G 5W Boondock Edge
2008 M-B G500
