Newbie help
So i decided to go the antifreeze route in winterizing 2015 T@G. I put in 3 gallons and turned in oump amd faucet but no pink. A few drips of water. Cranked it up so leaning. How long should it take to come out of faucet? Feel like I am doing something wrong. Any advice?
Was the pump working before? With the pump turned off, unscrew the filter cap on the intake side of the pump, clean the filter and replace the cap. Tighten all connections leading to the pump.
This may help. https://teardrop-trailers.vanillacommunity.com/discussion/464/need-winterization-advice-for-t-g-max
Yes it was. I will try that. Thanks!
@loriekt - don’t forget about the outside shower if you have one.
