Tri-fold Mattresses
Has anyone used a tri-fold mattress to replace the mattress in their T@G it seems to me that this could double as a sofa for when you want to sit inside rather than lay down. This is what I am thinking about,
https://www.mattressfirm.com/milliard/tri-fold-sofa-bed/mfiV000255011.html?utm_kxconfid=t6c7xqs93&gclid=CjwKCAjw-sqKBhBjEiwAVaQ9aw2slE5mJ46QXL9kFpeKMsIaoECXANXQxvgo-3izNXQexJKsrIBXIRoC7JYQAvD_BwE&gclsrc=aw.ds
Would this fit through the door or front window?
  • PatSeiner
    PatSeiner Member Posts: 5
    I currently have the Milliard 31 by 75 by 6 inch. It works great for me. I did add a 1 inch memory foam on top. I have not used it in a folded/chair position.
  • poliver
    poliver Member Posts: 33
    Hard to use the below deck storage.
  • packetjunkie
    packetjunkie Member Posts: 72
    I've found that there is a choice between comfort and accessibility - hard to get both for someone who needs more from a mattress setup than the stock mattresses. I may put in some of the gas struts to help, but with my Ultimate setup, I tend to keep just small things in the storage below that I can access with a 6" post I can put in place.
