Was measuring to make a cover for the belly vent (to prevent the sucking up of dust for delivery into the cabin) and came across this item. Found it to be quite warm to the touch. Appears to a heat dissipation device of some sort? Trailer is parked in the yard, not drawing current from the battery. Must be for the solar system?
The safety decice to cut the propane gas.
I believe it cuts tbe gas when thr galley rear door is closed.
I do not have one on my 2018, which I am glad since it is a 12-volt power draw.
I shut off my propane at the tank when not being used.
